MWI with AIM-CUE on 2851.
timkaye
Hi.
First off. I'm new to voice so don't fully understand the differences between ephones and ephone-dn's.
That said, MY 2851 running CME with an AIM-CUE installed does not provide a Message Waiting Indicator (MWI)via either a red light on the handset or an envelope on the display.
Ive seen some information which suggest MWI won't work with anything other then a 5 digit extension.
My configuration has a 4 digit extension.
I'd appreciate any help.
I've attached a configuration for reference.
The 8000 and 8001 are the MWI on/off vales. From what I can gather I need to create an ephone-dn for these values?
Appreciate any information!
Tim
david-lima
Level 4
Level 4
Hi Tim, you will need to create this ephones-dn for MWI.
Enter the command ephone-dn in order to create the extensions for the Cisco IP phone lines.
Router(config)#ephone-dn 80
Router(config-ephone-dn)#number 8000....
Router(config-ephone-dn)#mwi on
Router(config)#ephone-dn 81
Router(config-ephone-dn)#number 8001....
Router(config-ephone-dn)#mwi off
Check this good document
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
Hope this help
David
