WLC Dhcp error
Jan 7th, 2009
Hi!
Recently i discover some issues with the h-reap APs. The problem is that the wireless clients cannot get ip address from the local dhcp server.
I found this error that hope it will help to solve this problem.
AP '00:22:0d:47:f1:90'
with static-ip configured as '192.168.137.31' has fallen back to the working DHCP address '192.168.137.91'.
Any ideas?
WLC 4402 v.4.0.217.0
The h-reap 1242aps are connected to a CE520 series PoE.
Thanks in advance
sschmidt Wed, 01/07/2009 - 07:33
  • Cisco Employee,
Well the message you are seeing is probably related to this configuration in 4.0 controller code:
http://www.cisco.com/en/US/customer/docs/wireless/controller/4.0/configuration/guide/c40lwap.html#wp1105314
This is an expected behavior of the AP. It has been designed to be
helpful in situations wherein an AP may need to fallback to a DHCP IP
address for it to be able to reach the controller. This behavior
prevents the inconvenience of having to take down the AP from the field
and reconfigure it for the AP to be able to connect to the controller
(Situations where wrong Static IP address got accidentally configured or
where the AP needs to go to a MAP / RAP on another subnet to connect to
the controller).
Are you having any issues with the connectivity on the static address?
uosambela Mon, 01/12/2009 - 03:34
Hi sschmidt!
i`m sorry for the delay.
First of all, thanks for the info.
And i have no problems with those AP. It was just a moment that the wan link was lost.
Thanks you.
Bye
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
