Access failed VPN 3000
Jan 7th, 2009
I have a structure of remote access with VPN 3000 and ACS, authenticating the users for digital certificate, in a root here what is in the womb in Prague.
They are not getting user any more access, crop down some logs collected in the VPN 3000, in the ACS request of authentication does not bring any near.
All the digital certificates are cost, I updated in the passed mes.
drolemc Tue, 01/13/2009 - 14:35
If nothing was changed on your configuration that would affect the certificates then there
is no reason for it not to work. It is likely that the certificate became corrupted and so invalid.
Is it possible for you to reenroll the certificate? I believe this would solve your issue.
