01-07-2009 06:46 AM - edited 03-15-2019 03:22 PM
I currently have a site to site VPN set up between our head office (ASA5510) and a remote site (877w)
We are running CME 4.3 at the head office on a 2821 Router
The head office has data network and voice network
The remote site just has one network
I have managed to set up a phone (7945) at the remote site and successfully register it to the CME system
I receive a dial-tone but whenever I make or receive a call the phone resets and re-registers.
Sometimes I can make a call before it resets
Can anyone explain why it would do this or steps I can take to resolve this issue.
Can the 877w be set up with a voice vlan?
Chris
01-07-2009 07:07 AM
Just looked at the debug for the phone on the web interface, it is full of these entries
15:01:00 10: Name=SEPxxxxxxxxxxx Load= SCCP45.8-4-1SR1S Last=TCP-timeout
Not sure if that is related
01-07-2009 09:02 AM
Hi Chris,
What sounds like is happening is that when the call is placed, it takes up all of the bandwidth available. Then, TCP keepalives are not able to make it over the connection, and the phone unregisters.
I would set up voice QoS so that both your signaling and your audio have priority queueing.
hth,
nick
01-07-2009 12:30 PM
Do you know how I go about setting up voice QOS on a 877 Router? Is any documentation available
Chris
01-07-2009 04:01 PM
This should help, if you have more questions, do a cisco.com search for "LLQ" qos.
Sample config:
class-map match-any voice-control
match ip dscp af31
match ip dscp cs3
match access-group 101
class-map match-any voice-RTP
match ip dscp ef
match ip rtp 16384 16383
policy-map Voice-QoS
class voice-RTP
priority [bandwidth-value]
set dscp ef
class voice-control
bandwidth [bandwidth-value]
set dscp af31
class class-default
fair-queue
!For MGCP
access-list 101 permit udp any any range 2427 2428
!For H.323
access-list 101 permit tcp any any range 1718 1720
access-list 101 permit tcp any any eq 1731
!For Skinny (phones registered to CCM)
access-list 101 permit tcp any any eq 2000
!For Sip
access-list 101 permit tcp any any eq 5060
interface x/x
service-policy output Voice-QoS
Note that for some versions of IOS, the command 'match ip dscp' needs to be replaced with 'match dscp'.
What this will do is take any traffic marked as a DSCP of 'ef', or any unmarked RTP traffic, and marks it as RTP traffic and sets the DSCP values accordingly. This traffic is sent to a priority queue. Then, it takes any traffic marked as DSCP of 'af31' or running on port thatis used for control traffic, marks it as control traffic (and sets the DSCP if needed), then puts it in a queue. All other traffic is sent to the fair-queue.
Estimate about 8K of call-control traffic per call. You can find out how much bandwidth you will need for RTP traffic with the voice-call bandwidth calculator found here:
http://tools.cisco.com/Support/VBC/do/CodecCalc1.do
Just be careful when you apply this QoS policy that those 100 and 101 access-lists aren't overwriting any ACLs that you already have configured.
hth,
nick
01-08-2009 04:03 AM
01-08-2009 07:13 AM
You will only need this on your WAN interface. In this case, it will be your FastE going to your cablemodem/DSL or whatever you're connecting to the internet with.
No idea on the router locking up - run the latest code you can fit on the flash and it will probably stop happening.
hth,
nick
01-08-2009 07:22 AM
I put it on the inside interface (BVI1), that was probably why, I have the latest IOS.
It is an ADSL Router so I have an ATM0 and ATM0.1 subinterface, I think I can place the "service-policy output Voice-QoS" command below pvc 0/101 in my config, is this correct?
01-08-2009 08:53 AM
As an update to this, I tried applying it to pvc 0/101. It seemed to accept the request but when I checked the config after it did not appear.
I applied it to ATM0 and did appear in the config after and applied the policy but the problem with my phone re-registering still occurs and no traffic seems to be using the policy (please see below)
From the original post you mentioned the phone is probably taking all the bandwidth, is there a policy I need to apply that restricts the bandwidth it can use?
show policy-map interface atm 0
ATM0
Service-policy output: Voice-QoS
queue stats for all priority classes:
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
Class-map: voice-RTP (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip rtp 16384 16383
0 packets, 0 bytes
5 minute rate 0 bps
Match: ip dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Priority: 128 kbps, burst bytes 4470, b/w exceed drops: 0
QoS Set
dscp ef
Packets marked 0
Class-map: voice-control (match-any)
3 packets, 508 bytes
Match: ip dscp af31 (26)
0 packets, 0 bytes
5 minute rate 0 bps
Match: ip dscp cs3 (24)
5 minute rate 0 bps
Match: access-group 105
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
bandwidth 128 kbps
QoS Set
dscp af31
Packets marked 3
Class-map: class-default (match-any)
58331 packets, 4346742 bytes
5 minute offered rate 75000 bps, drop rate 0 bps
Match: any
Queueing
(queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
Fair-queue: per-flow queue limit 16
Chris
01-08-2009 09:12 AM
Hi Chris,
Applying QoS on an ATM circuit is different, and unfortunately I'm not very familiar with doing that.
I would start with a cisco.com search for LLQ on ATM.
hth,
nick
01-09-2009 01:54 AM
I have added 'qos pre-classify' and I can now see voice traffic on the VPN when using 'sh policy interface atm 0'
Unfortunately the phone is still re-registering after I make or receive a call from it, does anyone know where I can go from here?
01-09-2009 03:39 AM
After all this, I managed to get this working by disabling Skinny inspection on the ASA
01-08-2009 04:32 AM
Hello Chris.
I am trying to do tha same that you have, but the phone 7940, doesn't try to register to de remote CME. When the phone stars he get's the ip address but then the "protocol application invalid" appears in the display and it stays like this.
Did you have this problem, can you show me how you have your DHCP poll configured, because it seems that the question is there.
thanks in advance
JG
01-08-2009 06:35 AM
I didn't have that problem, my DHCP setup should be in the config I attached earlier.
The main issue I had was setting up the NAT exemptions and Interesting traffic for the Site-Site VPN connection between the remote site and ASA firewall. This had to be reconfigured to see my 192.168.100.0/24 voice network.
I also had to add a route on the ASA to see the Voice Network.
If you could post your configs I can compare them to mine
Chris
