Warning message
ASA EIGRP routing
Answered Question
Jan 7th, 2009
I have an ASA5510 ver8.0(3), its running EIGRP. From the ASA all EIGRP routes/subnets are learned and are pingable. My issue is when I set my PC's default gateway to the ASA inside interface, I'm unable to reach any other subnets or eigrp routes that my ASA could reach.
Any suggestions?
Thanks.
Correct Answer by Jon Marshall about 8 years 7 months ago
Fred
Are the other subnets reachable via the inside interface ? If so the ASA would need to send the traffic from your PC back out the inside interface and you need to set this up -
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml
Other than that have you
1) checked that what you are trying to ping has routes back to your PC subnet
2) that you are allowing ICMP with access-lists on the relevant interfaces
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 01/07/2009 - 07:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Fred
Jon
