ip verify unicast reverse-path
Answered Question
Jan 7th, 2009
On a router and ASA firewall, should RPF be enabled on all the given interfaces.
Correct Answer by mikegrous about 7 years 9 months ago
This is my understanding as well.
Correct Answer by Jon Marshall about 7 years 9 months ago
You should generally apply it at the exit point to your network because within your network you may well have asymmetrical paths. Have a look at this doc which goes into where Unicast RPF should be used -
Overall Rating: 5 (4 ratings)
mikegrous Wed, 01/07/2009 - 08:29
typically youd only apply it on your WAN interface as you should be trusting your LAN routes
cisco_lite Wed, 01/07/2009 - 11:52
What is difference between
ip verify unicast source reachable-via any
What is the default Unicast RPF mode; loose or strict.
mikegrous Wed, 01/07/2009 - 11:55
In reguard to the first question:
R8(config-if)#ip verify unicast ?
reverse-path Reverse path validation of source address (old command format)
source Validation of source address
cisco_lite Wed, 01/07/2009 - 12:12
From this I understand that both of the above commands have the same effect, where in reverse-path is an old command.
Please confirm.
