HP DL380 G5 for UCM
Jan 7th, 2009
Will a DL 380 G5 with the quad processor and more than 4 GB of memory work for a UCM 7.x installation?
The Cisco supported specs say a dual processor with 4 GB memory are required and wanted to see if the newest HP server available would be an issue.
Manish
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 01/07/2009 - 10:11
  • Cisco Employee,
  • Hall of Fame,
    2011
but look for what the support is:
Table 41. Supported Servers for Cisco Unified Intelligent Contact Management Enterprise and Hosted and Cisco Unified Contact Center Enterprise and Hosted and Cisco Unified Customer Voice Portal
DL380-G5
Dual-processor Xeon 5345 2.33GHz Quad Core
Cisco 7800 Series Media Convergence Servers
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
does not show support for that server yet, only dual processor.
java
if this helps, please rate
htluo Wed, 01/07/2009 - 10:40
  • Red, 2250 points or more
You're right. In that case, I would err on the safe side and assume it's not supported.
For many vendors (including Cisco), "working" and "supported" are two different things. You could make something working, but it might not be backed by the vendor if they haven't tested it.
Jaime Valencia Wed, 01/07/2009 - 10:48
  • Cisco Employee,
  • Hall of Fame,
    2011
i totally agree with you but in this case best guess is that it's not only not supported (at least not right now), but cannot be installed since the PCD is very strict when it comes to HW checking and part numbers to allow installation.
the only real way to find out would be to try to install it, worst case scenario is you'll end up with a message that it's an unsupported platform.
java
Rob Huffman Wed, 01/07/2009 - 11:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Manish,
Just to add a note here to the good info from Java and Michael.Here is a good recent example of where the install of CUCM fails during the Hardware Compatability Check on a HP DL380 G5;
The install fails with the below message:
Critical Error:
The Hardware you are using is not supported for this product. Installation will now halt.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc2a0e0
Hope this helps!
Rob
mdaswani Thu, 01/08/2009 - 06:32
Thanks Rob and everyone else for your posts...I think this answers my question..
Manish
