4510R- IOS upgrade suggestion
Jan 7th, 2009
  • Gold, 750 points or more
Hi All,
Iam planning to upgrade IOS on dual SupV 4510R to most recent 12.2.50-SG to support ip tracking feature for Internet reachability.
Current IOS: cat4000-i9s-mz.122-25.EWA4
The switch has BGP/OSPF/EIGRP protocols with SSO redundancy. In the 12.2.50 train, the naming convention for IOS is little different. Will
ENTERPRISE SERVICES W/O CRYPTO
cat4500-entservices-mz.122-50.SG.bin
OR
IP BASE W/O CRYPTO
cat4500-ipbase-mz.122-50.SG.bin
is recomended. My choice is 1st one, but would like to get openions from gurus. Also, upgrading IOS does not need SUP firmware upgrade. is that correct.?
Thank you in advance
MS
Overall Rating: 4 (1 ratings)
Jon Marshall Wed, 01/07/2009 - 09:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
MS
You should use Feature Navigator to choose which IOS feature set you need. The IP Base will not have EIGRP/BGP/OSPF support - for that you need Enterprise Services -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
No, you should not have to upgrade the firmware.
Jon
glen.grant Wed, 01/07/2009 - 11:35
  • Purple, 4500 points or more
Not sure ipbase would cover the advanced routing protocols , you would need enterprise services.
mvsheik123 Wed, 01/07/2009 - 12:27
Thank you both. I will go with enterprise version. Also, for IOS upgrade with dual sups, Iam refering to the link
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/20ew/configuration/guide/RPR.html#wp1104060
I need to run both the below commands (to upload IOS to Active & stdby sups)
Switch# copy source_device:source_filename
bootflash:target_filename
and
slavebootflash:target_filename
I do not have to kill the redundancy to upload the IOS. Please clarify.
Thank you
MS
mvsheik123 Fri, 01/09/2009 - 08:03
Any suggestions..?
Thank you
MS
Roberto Salazar Fri, 01/09/2009 - 09:01
>>>> Simply uploading an IOS to the bootflash of the standby will not kiil the redundancy.
I hope that answers your question.
