Data and Voice configuration on a switchport
Jan 7th, 2009
What is the best configuration on the switchport for data and voice. The configuration will for a cat4500. Thank you
Overall Rating: 5 (1 ratings)
pmpesha Wed, 01/07/2009 - 10:46
thanks for replying, I do understand that I need two separate vlans for data and voice. Do I have to spesify the native vlan?, does the port have to a trunk port? Thank you.
Brandon Buffin Wed, 01/07/2009 - 11:00
If not specified the access vlan will be 1. If it is something different in your environment, you will need to specify it using "switchport access vlan x". You do not need to specifically configure a trunk. In the case of an IP phone the trunk is negotiated automatically.
Hope this helps.
