01-07-2009 09:52 AM - edited 03-06-2019 03:18 AM
Have a quick quesiton for you, I have a switch that I would like to change the IP address on, when I changed it even though I can ping it from other routers on tne network I cannot log into it and I see that my tac server cannot get to it as well. I went from vlan90 to the new one vlan192. Vlan 192 isn't working am I missing something?
Solved! Go to Solution.
01-07-2009 11:27 AM
Maybe you could try clearing the crypto keys and see whats happens.
01-07-2009 10:10 AM
aaa authentication login default group tacacs+ local
States use TACAS if TACAS is unavailable use local database. Local database would be:
username cisco password cisco
when you telnet to the switch do you get a username password prompt?
01-07-2009 10:27 AM
That is the think although I can ping from any router or my destop when I try to telnet
into it I cannot get a sign on screen just times out. So that is what is confusing
01-07-2009 11:27 AM
01-07-2009 01:53 PM
Grant wow that worked!!!! well actually I was going to do it but never got around to do it then all of a sudden I was able to log in so I guess the old crypto keys timed out or something? By the way how do you clear the crypto key...is it just a simple clear crypto key?
01-07-2009 03:59 PM
Think it is crypto key zeroize rsa" or something close to that , then you have to recreate the keys in config mode with "crypto key gen my rsa and whatever key size you normally use .
01-08-2009 06:51 AM
Just an update on this, it wasn't the crypto key. I moved another switch to the same subnet as the first one and had the same issue. I cleared the crypto key but still wasn't able to log in. I went to my tac server and wasn't able to ping the switch on the new IP address. So I cleared the arp cache on the switch and then I was able to log in. I went back to my tac server and tried to ping the new ip address and this time it worked. I moved another switched and cleared the arp cache and had no issues so it was the clearing of the arp cache that did the trick......But thank you everyone for helping out I appreciate it!!!!!!
