RME System Collection/Polling scheduled jobs
Answered Question
Jan 7th, 2009
How do I delete/disable System Collection/Polling Schedule jobs?
Correct Answer by Joe Clarke about 8 years 2 months ago
Replace NMSROOT with the path into which CiscoWorks was installed. Run this command from a DOS shell as a local Administrator.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 01/07/2009 - 10:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Inventory or Config?
kathegaj2 Wed, 01/07/2009 - 10:41
Inventory...seems there wasn't one there. I added one and it told me ICSU0039: Successfully updated System Job Settings notification. I read a little further (!) and decided the size of my network would be better off collecting and polling inventory in smaller increments but couldn't find a way to back the job out or delete it.
Joe Clarke Wed, 01/07/2009 - 10:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Inventory collection and polling are always run. They cannot be disabled. You can configure collection to run in the distant future, however. Typically, we recommend inventory polling runs daily, and collection runs weekly. The overhead is typically minimal as this is just SNMP polling of containment information.
kathegaj2 Wed, 01/07/2009 - 11:10
I cannot find evidence that they have ever run! Under Job Management>RME Jobs...no collection results. When I "updated" the default, there wasn't any information in the schedule fields, I added the day and time and my email(it didn't take what I submitted either...made 00:45:00 to 00:17:03)
Joe Clarke Wed, 01/07/2009 - 11:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Have you reinitialized your cmf database?
kathegaj2 Wed, 01/07/2009 - 11:48
No, I don't know what this is...
BTW I am in a LMS class right now and you are famous! So happy to meet you!
Joe Clarke Wed, 01/07/2009 - 12:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This could be a jrm problem, then. What version of LMS is this? Please post the output of the pdshow command as well as the ICServerUI.log.
Jason Fraioli Wed, 01/07/2009 - 12:26
What LMS class are taking? I'd appreciate recommendations for training.
kathegaj2 Wed, 01/07/2009 - 13:11
Global Knowledge: Implementing CiscoWorks LMS! Awesome class! Mike Fiedler is a rockstar of educators, passionate and knowledgeable, nothing close to Joe but highly recommended =-)
kathegaj2 Wed, 01/07/2009 - 13:03
Sorry it took so long, communication to server is slow over VZ connection through VPN...
Joe Clarke Wed, 01/07/2009 - 13:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I need to see the ICServerUI.log as well.
Joe Clarke Wed, 01/07/2009 - 23:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I must not have scrolled down far enough. However, the attachment appears to have gotten lost in the forum. Can you repost it?
kathegaj2 Thu, 01/08/2009 - 09:46
Here it is again...
Do you think this may have anything to do with why my Netconfig jobs "Failed" in this manner:
Deploy succeeded, Synchronization of RME archive with Device Config failed
Joe Clarke Thu, 01/08/2009 - 11:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of RME is this?
Joe Clarke Thu, 01/08/2009 - 12:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The line numbers in your stacktraces do not line up with the RME 4.1.1 code. Since the jobs are not showing up, it may require you to re-register the system RME jobs. IF you're run Windows, run:
NMSROOT\bin\perl -I NMSROOT\objects\perl5\lib NMSROOT\dbupdate\dbupdate.pl NMSROOT\rigel\scripts\rme\createJobs.txt
If on Solaris, run:
/opt/CSCOpx/bin/perl /opt/CSCOpx/dbupdate/dbupdate.pl /opt/CSCOpx/rigel/scripts/rme/createJobs.txt
Then restart Daemon Manager, and see if your inventory jobs show up.
kathegaj2 Thu, 01/08/2009 - 12:46
Sorry Joe, I don't understand how to run this script on this server.
Correct Answer
Joe Clarke Thu, 01/08/2009 - 12:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
kathegaj2 Thu, 01/08/2009 - 13:37
yeaaaa I tried that and it won't recognize the file or directory...
Joe Clarke Thu, 01/08/2009 - 14:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post a screenshot of what you're executing, and the error you receive.
kathegaj2 Mon, 01/12/2009 - 10:54
D:\Program Files\CSCOpx\bin>perl -I\PROGRA~1\CSCOpx\objects\perl5\lib\PROGRA~1\C
SCOpx\dbupdate\dbupdate.pl\PROGRA~1\CSCOpx\rigel\scripts\rme\createJobs.txt
This gyration worked but nothing happened.
(don't know if terminal monitoring is on so...)
I restarted daemon manager just in case... I think this did the trick. Will let you know...
