MGCP-After call disconnected from pstn,IP phone is ringing
Jan 7th, 2009
In my ccm6 and MGCP gateway if I disconnected the call from PSTN, the IP phone still ringing for about 15-20 seconds.
Any one please help where is such kind of parameter in Callmanager
1 vote
Eldho E Kuriakose Thu, 01/08/2009 - 00:33
ok
but this is an MGCP gateway.Is in MGCP gateway is controlled by callmanager?
Anyway I will try...
Nicholas Matthews Thu, 01/08/2009 - 06:47
CCM will not control the analog telephony of the FXO, which is where it sounds like you may be having the problems. This is in contrast to a PRI where CCM controls the signaling on the PRI.
Eldho E Kuriakose Thu, 01/08/2009 - 14:05
dear,
i apllied no battery reversal,but its again the same pblm.
I think there may be any service parameter in CCM.
Please suggest
Nicholas Matthews Thu, 01/08/2009 - 15:11
I can't think of anything else off the top of my head. You could put a TAC case in to pull the traces and debugs.
-nick
islam.kamal Sat, 04/06/2013 - 12:23
Did you check the below link
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
please try the below commands onyour gateway
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone CN  (CN is for your country)
timeouts interdigit 2
timeouts call-disconnect 1
timeouts wait-release 1
mgcp
mgcp bind control source interface fas0/0
mgcp bind media source interface fas0/0
no mgcp
mgcp
Thank you
please if this will help
