BACD on MGCP
Jan 7th, 2009
I have CUCM 6.0 running in the network, Cu has remote site where we required BACD should runn
I have 2811 router with 12.4 15T IOS
I need a running config of BACD script.
Consider my dial in number is 8 digit
Please post guys i need it urgently.
I have extension in my network starting with 701501 701502
Also just the info site has only BRI line
What i required is when smeone dial that number it should say thkyou for calling XXXX please dial the extension number you wish to reach 2
And when someone dial the extension number it should go to the extension.
my dial-peer configuration will be
dial-peer voice 1 voip
session-target ipv4:loopback ip address
destination-pattern XXXXXXXX
service aa
I need BACD running configuation
Arshad
redesfusionet Fri, 04/10/2009 - 20:12
I see no one answer your call. You still need assistance here? Let me know
Ayodeji Okanlawon Fri, 04/10/2009 - 21:53
  • Cisco Designated VIP,
    2017 IP Telephony
To run BACD you need tcl scripts and tcl scripts is not supported with MGCP, beacuse for this to fuction the gateway needs to local control of calls whic MGCP does not have
