site to site vpn problems
Jan 7th, 2009
help required
i have set a small network on my home lab to practice
site to site vpn using certificates for authentication
but have run in problems
the scenario is this have configured a Pix 515 running
os 7.0(5) (which represents a head office) with a dmz
on which resides a windows 2000 server that has been
configured as a stand alone root CA and a cisco 1721
Router running c1700-adventerprisek9-mz.123-18
(that represents a branch office), The idea is that both
the Pix and the Router obtains its root and identity
certificates from the CA using the cut and paste method
(have tried using scep and doing it out of band as well)
the Router obtains its certificates over an encrypted tunnel
the tunnel initialy uses pre-shared keys for authentication
once the Pix and Router have their certificates their configs
are changed and certificates are used for authentication.
getting the certificates onto the Router and the Pix was
no problem the problem is when i try using certificates for
authentication the tunnel will not come up and i have no
idea why.
i have included the configs for the Router and Pix and the debug
crypto isakmp output for the Pix as attachments.
incidentialy i cannot get a site to site vpn between 2 Routers using
certificates to work either but a site to site vpn between 2 Pix's
running 7.0(5) with the remote Pix obtaining is certificates over
an encrypted tunnel works perfectly i have included this setup in
a file called pix-to pix tunnel.
the site to site vpn between the 2 cisco routers consist's of
1721 running c1700-adventerprisek9-mz.123-18
and
2621 running c2600-advsecurityk9-mz.124-1a
for remote router (2621) have tried certificate enrollment using scep
out of band and over an encrypted tunnel all methods allow me to obtain
certificates but am unable to use them for authentication
would appreciate someone taking a look to help me try and figure out
where the problem lies.
regards
Melvyn Brown
