Arrowpoint cookie expiration
On a CSS, if a manual expiration time (say two hours) is set for an arrowpoint-cookie, does the expiration time get reset with every subsequent transaction through the switch? Or is the expiration time set once, at the initial HTTP GET request, and the cookie vanishes at it's expiration time?
If the cookie expiration time isn't constantly updated, then it's possible that a user might lose his cookie after two hours (even though he's only been idle for a minute or two) and lose his server persistence.
ciscocsoc Wed, 01/07/2009 - 23:59
The CSS command reference manual under arrowpoint-cookie expiration includes the information that:
"If the cookie has expired, the CSS sends a new cookie that includes the server
where the client was stuck. This will allow for the appearance of an uninterrupted
Reading the manual, the cookie is not continuously updated, but is replaced as it expires. The whole set of arrowpoint commands are worth reviewing to ensure that you get the effects you need.
Gilles Dufour Thu, 01/08/2009 - 01:52
The arrowpoint-cookie is static.
It never expires.
It never changes.
But, we can set an expiration time inside the http response when we send the cookie to the client.
This is the client browser that will expire the cookie and stop using it.
Once the browser has expired the cookie it stops using it.
The CSS will see a request with no cookie it will send a new one with a new expiration time.
Well, now we've got two opposite answers:
One says that when the cookie expires it is still sent to the CSS by the browser which will then replace it with a new cookie, so the user will remain stuck to the same server.
Another says that once the cookie expires it is removed from the browser, so that the CSS would see the incoming traffic as an entirely new session, and make a new balancing decision and assign a new cookie. This makes more sense to me as it is how I believe browsers handle cookies.
I guess I'll need to do some testing to find out.
And it turns out that you are both right...
If you set a cookie expiration time, and DON'T set arrowpoint-cookie browser-expire, then the CSS will note the expired cookie and reset a new one. Not sure what this gets you over a non-expiring cookie, except maybe it will allow for recycling of IDs if you've got gazillions of sticky customers.
If you set cookie expiration time AND set arrowpoint-cookie browser-expire, then the cookie vanishes from the browser upon it's expiration time, and the CSS has to make a brand-new decision.
