Converting from Unity 5x Voicemail Only to Unified
virverma Wed, 01/07/2009 - 19:27
  • Silver, 250 points or more
I would recommend to get new licenses.
It may not create any issue in working with old licenses but moving to different design so its always better to get new licenses.
Also, if you already have licenses for voicemail only solution then it should not cost anything extra.
Thanks!
STEFAN CHRISTEN Thu, 01/08/2009 - 05:17
Hi Jason
If your company is an Advanced US Partner then you should ask your question at the PDI Helpdesk.
http://www.cisco.com/go/pdihelpdesk
Or check out the Unity 5.0 Ordering Guide:
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/ciscounity5_og.pdf
You can find more guides on the Unified Communications Partner Web Site under:
http://www.cisco.com/web/partners/sell/technology/ipc/index.html
Hope this helps.
Stefan
