QoS issues for communication between cisco & linksys ip phones
Jan 7th, 2009
I have some Cisco ip phones and linksys ip phones which connected to LAN switch (3560G) and no configuration relate QoS.
The poor quality occurred when communicated between cisco & linksys ip phones, but communicate for cisco-to-cisco or linksys-to-linksys is normal status.
I need to activate QoS on LAN switch?
What QoS setting suitable?
Thanks for help.
Nicholas Matthews Thu, 01/08/2009 - 06:46
I don't believe you're going to run into QoS problems in this scenario. It takes very high jitter or latency, which you should not get going over a single switch.
This is more likely an interoperability problem, and has to do with the media that they are exchanging.
I would get a packet capture and use Ethereal to do a voice stream analysis and see what that turns up.
They may have RTP stream trouble, or codec trouble.
