Datacollection problem in Ciscoworks
Jan 8th, 2009
In Campus Manager under Data Collection All the devices are not present. After giving the Start Data Collection also.
Joe Clarke Thu, 01/08/2009 - 07:32
Enable core, corex, framework, and frontend debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options, then run a new Data Collection. Post the ani.log along with an example device which is present in DCR, but missing from Campus Manager.
akash03lingam Thu, 01/08/2009 - 20:32
DCR server is down now. If i run data collection will it find all the devices?
Joe Clarke Thu, 01/08/2009 - 20:34
No. DCRServer is key to Data Collection working. Why is DCRServer down? Did you shut it down?
akash03lingam Thu, 01/08/2009 - 20:35
Please tell the difference between Data collection and User Tracking Acquisition.
Joe Clarke Thu, 01/08/2009 - 20:41
Data Collection populates the Campus Manager database with device details, VTP and VLAN information, CDP neighbor data, and STP data. User Tracking Acquisition uses the Data Collection data to find end hosts (e.g. PC clients) connected to managed switches.
akash03lingam Thu, 01/08/2009 - 22:33
Where should i give this command?
If i give this command will it affect the production server?
please explain the pdshow command?
shareef800 Mon, 01/12/2009 - 13:15
pdshow command will NOT have anyimpact. Its just a show command. You are NOT starting or stopping any Server service to have an affect on.
If you are working on a Solaris server
find -name ./pdshow -print will give you the path of the command. After locating the path , cd to it and run ./pdhsow.
Please don't forget to rate..... :)
