Packets drops across DB application
Jan 8th, 2009
There is a database connection between two sites over point-to-point leased line. The database team has reported intermittent network connectivity issue.
Could you please explain the input queue and output queue counts on the serial interface.
We ran a script which threw in 100 ping requests per millisec throughout the night. 10 to 15 drops were noticed at msec level. Is this an problem ? Or is that the application is too sensitive to such acceptable drop limits.
infosankar Thu, 01/08/2009 - 02:26
You can try extended ping for 1000 packets from a point to point from this you can come to know is there any problem in the link.
And also you will see intermittent outage if more users are accessing the database. Also pls notice the txn and Rxn Load that high or not.
San
