01-08-2009 02:01 AM - edited 03-11-2019 07:34 AM
Can anyone tell me as i have I recently added an inside router to connect a second inside network to my PIX Firewall. Users between the Cisco Secure PIX Firewall and inside router can get to the Internet just fine, but they cannot talk to this new, inside network. Users on the new network can't get past the inside router.
Could you please tell me what might be the issue?
01-08-2009 06:38 AM
Is there a route to the new routers subnets?
01-08-2009 09:38 AM
Sounds like you are still using default gateway of pix. Does the pix have the route to the subnets on the other side of you new router?
Or as the other person stated, you need to make sure you are not using either static or dynamic routes that point to the new interface on the router.
Simple to fix, do a tracert from command prompt on system that can't hit internet. Watch last hop.
