01-08-2009 02:15 AM - edited 03-06-2019 03:18 AM
I need to buy an 1 Gbps Hub. Can anyone suggest a Good Branded Hubs...
Solved! Go to Solution.
01-08-2009 09:45 PM
Sounds like a SPAN will do.
Local SPAN, RSPAN, and ERSPAN sessions allow you to monitor traffic on one or more ports, or one or more VLANs, and send the monitored traffic to one or more destination ports. With Release 12.2(18)SXD and later releases, you can configure per-VLAN filtering on destination trunk ports.
Here are more details in SPAN and how to configure it:
01-08-2009 06:30 AM
I doubt you'll find a hub, however there are 10/100/100 switches that a pretty cheap (unmanaged). Here's an example-
Hope that helps.
01-08-2009 09:38 PM
My requirement is two nodes are connected like this below
MS--->BS..Actually i like to capture the packets between BS and MS..My requirement is i need to view the traces in two or more PC's.( i need to run Ethereal or Wireshark in those PC's and would like to capture the traces)..for the above case, can i use Switch?..( since the debugs are pumped in a very high rate, that is the reason why i asked about a 1 Gbps Hub)..if you let me know, how to achieve this using a switch, that would be of great help...
01-08-2009 09:45 PM
