01-08-2009 02:33 AM - edited 03-18-2019 10:15 PM
Hi Team
When CDR reporting runs for a date range with ART/CAR, the report generation fails, and the "30023: Data is not available for the date range selected" error message appears, or the CAR tool is not able to generate reports for a certain date range.
Plse provide the solution for the problem and as well as could we fetch previous data .
Vaibhav
01-08-2009 05:31 AM
Hi Vaibhav,
Great answer from Jorge;
There are also some great tips in this Tech doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml
Hope this helps! Let us know.
Rob
01-08-2009 07:12 AM
Hi Rob,
I tried all of the above and still have a problem.
When I log on CAR and go on CDR menu -> search (I tried for users and gateways) I get the report for the date period that I entered. But when I go on any kind of reports: Users Report (or Device Reports or System Reports) I get the following error:
30023: Data is not available for the date range selected. Data is available from xx to yy.
Do you have any idea or suggestion what should I do to be able to generate these kind of reports?
Thx,
Jelena
01-08-2009 10:10 PM
Hi Rob / Jelena
ok i got the solution...but anyone can tell how to retrieve previous data...after doing this latest record is generated but how could we take older data from the same.
Vaibhav
01-09-2009 12:58 AM
Hi Vaibhav and Rob,
I found the solution of my problem. Devices didn't have assigned owner ID. For reports to work you must have associated device to user and vice versa.
Hope this will help,
Jelena
01-09-2009 02:32 AM
Hi Jelena
i am not getting.
i just want to know could we fetch previous date after getting this error.meand after doing mentioned troubleshooing could we able to fetch older reports for any valid range of data.
Vaibhav
