01-08-2009 03:00 AM - edited 03-11-2019 07:34 AM
I have PIX 515E ver 7.2. I have generated a key for ssh access with a command
crypto key generate rsa modulus 1024
and I saved it like
wr mem
then I allowed my workstation Ip for ssh access.
it worked fine, but after sometime the generated keys disappear and I should generate the key again to get access. Can anybody help me to retain the keys anytime?
01-09-2009 03:19 AM
' write mem ' command will not save the RSA key in PIX . For that you need to use " ca save all" command .
01-12-2009 03:47 AM
thanks for the help, but i have used ca save all as u said and still the key disappears. any other option?
01-12-2009 08:50 PM
I have faced the same problem and when I replaced theold flash memory, it was resolved.
