No NAT in PIX 515 E
I need to configure a PIX without NAT and I don't know how to do it. Can anyone help me please?
I have;
outside interface with 192.168.7.0/24
inside interface with 10.79.10.0/24
interface2 with 192.168.24.0/21
I need that 10.79.10.0/24 goes to the outside without doing NAT over it (because we have another FW in another place outside)
How can I do it?
Thanks, Regards
Eneko
sachinraja Thu, 01/08/2009 - 05:42
  • Red, 2250 points or more
hello eneko
YOu gotta use nat 0 statements to do a no-nat on the PIX.. the following commands should be in place:
nat (inside) 0 10.79.10.0 255.255.255.0 0 0
If there are more than one networks, you can assign an access-list and then allow the networks which have to be no-natted.
nat (inside) 0 access-list 101
access-list 101 permit ip 10.79.10.0 0.0.0.255 any
Let us know if this works fine.. all the best..
Raj
cisco24x7 Thu, 01/08/2009 - 05:58
  • Silver, 250 points or more
That is not entirely correct.
Depending on the configuration. Assuming
that you have no PAT/NAT configuration on the
Pix and that you use versin 7.x or 8.x,
"no nat-control" is on by default on the Pix
and the Pix will become a router. network
10.79.10.0/24 will be able to get to the
outside and return traffic can get back without
any issues, with the exception of icmp stuffs.
sachinraja Thu, 01/08/2009 - 06:45
Agree with David.. If it is 6.3 and less, you can use my solution, if it is 7.x or 8.x, you can use no nat-control.. but im not really convinced with nat-controls.. by statically defining no-nats, the administrator always has the control of what traffic goes through the firewall, without nat, which is critical to his network.. If by default, all traffic is allowed, isnt it a security risk ? and if there is no access-list on the inside network, then it will be a major mess !
Raj
