sschmidt Thu, 01/08/2009 - 08:22
  • Cisco Employee,
Currently this feature does not exist. You can schedule a radio interface to be on/off on a schedule but doing the same with an entire wlan is not possible.
meirelyahu Sat, 01/10/2009 - 23:12
ok,
How do I schedule the radio interface?
Meir
ericgarnel Thu, 01/08/2009 - 10:11
  • Gold, 750 points or more
If all the radios are on PoE switchports, you could write a script that turns off the switchports and run it through a cronjob
talmadari Sun, 01/18/2009 - 00:43
While using only the WLC (controller) you can't schedule work time for the WLAN.
If you will use the WCS you can schedule to enable specific (or all) SSID's on a specific (or all) AP's.
Trending Topics - Security & Network
