Use of Route Maps for default route
Jan 8th, 2009
I have tried to set the BGP no-export community for only the default route
between 2 routers.
I have tried the following configuration on the announcing router with no luck (have also tried using standard ACL's).
neighbor 195.50.113.250 remote-as 5635
neighbor 195.50.113.250 send-community
neighbor 195.50.113.250 default-originate
neighbor 195.50.113.250 route-map SET_NO_EXPORT out
ip prefix-list DEFAULT-ROUTE seq 5 permit 0.0.0.0/0
route-map SET_NO_EXPORT permit 10
match ip address prefix-list DEFAULT-ROUTE
set community no-export
Is there something different when using route maps and the default route?
Thanks in advance.
Overall Rating: 5 (1 ratings)
mikegrous Thu, 01/08/2009 - 06:13
It is possible. I did it differntly than you but it works for me.....Also you are missing route-map SET_NO_EXPORT permit 20.. Anything not matched in permit 10 will get denied.
This is how i accomplished it. 99.99.99.8 is sending the default route to R7..
R7
Router bgp 7
neighbor 99.99.99.8 route-map test in
route-map test permit 10
match ip address prefix-list 22
route-map test permit 20
ip prefix-list 22 seq 5 permit 0.0.0.0/0
____sho ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 37
Paths: (1 available, best #1, table Default-IP-Routing-Table, not advertised to
EBGP peer)
Flag: 0x8A0
Not advertised to any peer
8
99.99.99.8 (metric 2297856) from 99.99.99.8 (99.99.99.8)
Origin IGP, metric 0, localpref 100, valid, external, best
Community: no-export
R7(config-route-map)#
Harold Ritter Thu, 01/08/2009 - 08:22
  • Cisco Employee,
Paul,
The default route originated by the "neighbor default-originate" command is not subjected to the outbound route-map.
You can either apply the community to the default route on the inbound route-map at the receiving end or originate the default route using the following commands instead of the "neighbor default-originate" command:
router bgp xyz
netw 0.0.0.0
ip route 0.0.0.0 0.0.0.0 null0
or
router bgp xyz
redistribute static
default-information originate
paul-giles Fri, 01/09/2009 - 01:37
Thanks for your response and solution Paul.
I have also found that I could apply a route map directly to the default-originate which successfully invokes the no-export community.
neighbor x.x.x.x default-originate route-map SET_NO_EXPORT
Thanks again.
