01-08-2009 06:27 AM
Where can I get a console cable for the Cisco VPN 3000 Concentrator? The place I purchased the concentrator from did not send me one with it.
JP
Solved! Go to Solution.
01-08-2009 07:11 AM
JP,
Since vpn concentrator console port is rs-232 complient you can buy two DB9 female to rj-45 adapters, one for the concetrator and one for the PC to use in COM1 port, then use a regular straight through CAT5 cable , this is the way I do it, and is practical as suppose to use the straight through rs-232 serial cable.
http://www.sealevel.com/product_detail.asp?product_id=787
As for the regular cable that concentrator comes with you can use this.
http://www.stonewallcable.com/product.asp?dept%5Fid=35&pf%5Fid=SC%2DS9%2DFF
Adidtional info for your initial concentrator seup -
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/3_6/getting/gs2inst.htm#1050260
PLS rate helpful posts
01-08-2009 07:11 AM
JP,
01-08-2009 09:14 AM
Thanks for the info jorgemcse . . .
