ISDN Se0/0/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jan 8th, 2009
I had a customer that had an outage and need to find out why. Debugging q921 yields one way SABME. I know what this may indicate, but the error that I cannot decipher is
"ISDN Se0/0/0:23 Q931: Ux_DLRelInd: DL_REL_IND received from L2"
Anyone know what this means???
smalkeric Sun, 01/18/2009 - 19:19
You may try replacing the router and check the connection again.If the problem is not with the router check the PBX connection.
Michael Mistretta Sun, 01/18/2009 - 20:41
Interestingly, I think this was a provider issue, what exactly happened I have no idea. I showed up at the customer site and everything was working. Of caurse, the provider had no idea what went wrong nor what the fix was... Thanks for the response.
l-mathews Sun, 11/01/2015 - 07:51
What does the above q921 message mean?. For that matter what does SABME mean?
Not strong with voice. Let me know, Thanks
Carlo Poggiarelli Sun, 11/01/2015 - 09:50
Hi.
Set Asynchronous Balanced Mode Extended (SABME)
SABME is the first message sent during a Layer 2 connection sequence. Its basic purpose is to reset the link and prepare it for a new connection. SABMEs must be acknowledged by a UA.
Carlo
