Not able to access resources from Specifc DMZ to other DMZ
Jan 8th, 2009
We are not able to access the Deilvery Channel Network Managemnet VLAN, rest other networks, I can able to Access it.
I have Attached the NAT and ACL configuration.....
Packet are not at all reaching that Sunbet...
I suspect something wrong with NAT, I Tried to resolve this Issue up to my best with no sucess.
I appreaciate your support on this Issue...
Davy Ad Fri, 01/09/2009 - 06:05
Hi Jahangeer,
I would like to know if all these are in the same Network with Inside or Not
nat (Application)
nat (Middleware)
nat (Antivirus)
nat (Delivery)
nat (Extranet)
nat (Management)
jahangeer_abdul Fri, 01/09/2009 - 06:12
They are different DMZ's. Below is Interface Details, it can helps you to have Idea.
DB-FWSM# sh ip add
System IP Addresses:
Interface Name IP address Subnet mask Method
Vlan4 remote 10.10.195.10 255.255.255.0 manual
Vlan5 ATM 10.10.200.252 255.255.255.0 manual
Vlan31 Inside 10.10.231.10 255.255.255.0 manual
Vlan32 Database 10.10.232.10 255.255.255.0 manual
Vlan33 Application 10.10.233.10 255.255.255.0 manual
Vlan36 Middleware 10.10.236.10 255.255.255.0 manual
Vlan38 Antivirus 10.10.238.10 255.255.255.0 manual
Vlan42 Delivery 10.10.234.10 255.255.255.0 manual
Vlan43 Extranet 10.10.235.10 255.255.255.0 manual
Vlan44 Management 10.10.193.10 255.255.255.0 manual
Vlan61 FWfailover 172.30.1.1 255.255.255.0 manual
Vlan62 FWstate 172.30.2.1 255.255.255.0 manual
Vlan63 Outside 172.30.3.1 255.255.255.0 manual
Vlan159 IPTUtility 10.10.159.252 255.255.255.0 manual
