WEB Authentication Certificate on WLC4400 - Guest Access
Jan 8th, 2009
I need to know if there is a debug command to trouble shoot Web Authentication Certificate Issue for Guest Access. I'm currently troubleshooting an issue to verify if our Anchor controller is passing redirects to our web Server. Any advise would be appreciated.
This is on a WLC4404 Controller
Overall Rating: 3 (1 ratings)
sschmidt Thu, 01/08/2009 - 08:31
Is the redirect url configured with a name or IP address? If it is a name make sure there are no issues getting DNS resolution of the name.
The best troubleshooting method I can recommend is using a sniffer to capture the traffic at the anchor controller towards the webserver to see if the traffic passes to the webserver.
BeechLiam Wed, 02/25/2009 - 01:14
No issues with the DNS resolution. it may be an issue with the SSL certificate. root CA. I'm using code as we need to use this for ipsec vpn module. After a quick reboot , everything goes back to normal. thanks for the advise
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
