Disabling Call Log
Jan 8th, 2009
I want to know if I can disable call logs
on my IP Phone. I don't want any call records to get stored under Missed/Dialed/Received calls.
Is there any way to do it?
Please help..
Overall Rating: 5 (1 ratings)
virverma Thu, 01/08/2009 - 09:18
  • Silver, 250 points or more
hi Rohan,
try this..
go into settings on the phone and change the
AutoComplete to disable and he should have a 'CLEAR" softkey when goes into "Directories"
and only highlights "Placed Calls"
rohanpatel Thu, 01/08/2009 - 09:22
I cannot see auto complete. Can you send me the steps to do that...
I appreciate it. All I want is there should not be any logs under any category...
Jaime Valencia Thu, 01/08/2009 - 10:24
  • Cisco Employee,
  • Hall of Fame,
    2011
AFAIK this is still pending as an enhancement request.
the only current workaround is to clear them via XML
You put the following xml object on a http server and set it on idle url. Then set periodic time on the Idle Timer.
java
if this helps, please rate
