crow930us Thu, 01/08/2009 - 08:55
  • Bronze, 100 points or more
For monitoring there is show interfaces port-channel which verifies the EtherChannel configuration on the Cisco CMTS for the selected EtherChannel group. An example is here:
Router# show interfaces port-channel 1
Port-channel1 is up, line protocol is up
Hardware is FEChannel, address is 0000.0ca8.6220 (bia 0000.0000.0000)
MTU 1500 bytes, BW 400000 Kbit, DLY 100 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive not set, fdx
No. of active members in this channel: 4
Member 0 : Fast Ethernet1/0/0
Member 1 : Fast Ethernet1/1/0
Member 2 : Fast Ethernet4/0/0
Member 3 : Fast Ethernet4/1/0
Last input 01:22:13, output never, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
223 packets input, 11462 bytes, 0 no buffer
Received 1 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 0 multicast
192 packets output, 13232 bytes, 0 underruns
0 lost carrier, 0 no carrier
