challc2008 Thu, 01/08/2009 - 13:19
Thank you for the reply, I have followed everything but its not working still.
How do I know which port?
ip radius source-interface f0/0
Mark Yeates Thu, 01/08/2009 - 13:50
  • Gold, 750 points or more
The ip radius source-interface command allows you to statically configure the source port or IP address for the outbound radius requests from your switch. Generally you would source this from your management VLAN or loopback interface.
HTH,
Mark
challc2008 Fri, 01/09/2009 - 12:21
Latest update on this issue. I was able to see it in the logs that my user name is trying to authenticate but I was getting "Access Denied" because authentication protocols weren't matching. Do I need to specify some where in the switch to use PAP or PEAP?
