L2TP - LNS Decision by Domain
Jan 8th, 2009
I would like to share with all you about a L2TP scenario that I have.
There are some users connected in the LAC in the different networks and they need to remain separated between them.
Between LAC and LNS there is a single L2TP Tunnel with Nortel devices, and every thing is working fine.
Now I need to replace the LNS device to Cisco 7200 router and I have found a challange to do this.
The Nortel LNS Device can identify the customer by the Domain and then forwards it to the correct network. I have seem that Cisco can do the same feature, however in the Cisco Device I need to this configuration in the LAC device, and in this scenario I must do this configuration in the LNS Device (Cisco 7200).
Could anyone help me to find a better solution to replace Nortel LNS to Cisco LNS keeping the same configuration (by domain).
Please finf enclosed a simple topology to help to understand this scenario.
Thanks in advance
Cassio Gomes
Overall Rating: 1 (1 ratings)
drolemc Sun, 01/18/2009 - 09:37
Layer Two Tunneling Protocol (L2TP) provides a means to terminate the PPP connection from the end user at one location and transport the L2 data packets to another location. L2TP offloads much of the IP functionality from the aggregation device and allows more centralized network designs. A RADIUS server provides AAA.
AAA new-model
AAA authentication login default none
AAA authentication ppp default local group radius
AAA authorization network default local group radius none
AAA accounting network default wait-start group radius
vpdn-group 1
protocol any
virtual-template 1
terminate-from hostname cisco-tunnel
local name tunnel-gate
radius-server host auth-port 1645 acct-port 1646
radius-server key cisco
For further information click this link.
