mGRE in Provider network
Jan 8th, 2009
  • Gold, 750 points or more
I was reading one case study in CISCO IOS MPLS configuration of Cisco Press book. There they have three PE routers PE1/PE2/PE3 is connected with P routers in core as well as connected with CE1/CE2/CE3 of customer A respectively.
now what is the need of mGRE there as all the CE facing interfaces of PE routers are part of VRF custA? how can i take advantages of mGRE in such kind of environment? Actually i need deployment idea of mGRE in MPLS VPN environment.
thanks
Devang Patel
Giuseppe Larosa Thu, 01/08/2009 - 12:01
  • Hall of Fame,
    Founding Member
Hello Devang,
there are still big providers around the world that have decided to not implement MPLS.
So to provide L3 VPN services over a non mpls backbone you can use L2TPv3 or mGRE that are better then a mesh of point to point GRE tunnels.
Hope to help
Giuseppe
devang_etcom Thu, 01/08/2009 - 16:05
Giuseppe,
Thanks for your reply! but if you will take a look at that case study as well as in my post also mentioned that they are using MPLS VPN in their network!
regards
Devang Patel
Giuseppe Larosa Fri, 01/09/2009 - 05:12
  • Hall of Fame,
    Founding Member
Hello Devang,
I misunderstood your question and actually I haven't that book.
One possible reason could that to implement a DMVPN in order to provide CE to CE encryption but it is hard to guess without seeing the case study.
Hope to help
Giuseppe
