Parallel Outbound calls from IPIVR5.0/CRS Scripting
Jan 8th, 2009
Is it possible to make parallel outbound calls, from CRS scripting.
for e.g. If I use place call function in a loop, I can read the numbers to be called from a DB or xml file and dial out in a loop , which is a sequential dial.
1.However, can I generate parallel calls?
2.If 1. is not directly possible, can I write a java function and use in CRS scripting to generate parallel calls.
3.Is there any other way?
Rajesh
Borkes1985 Sat, 01/10/2009 - 22:48
i am interested in this problem too, please post your solution if you find.
1,2 dont exactly know, but seems to be not possible by means of CRS editor.
3. parallel triggering contacts, each initiating just a few outbound calls.
Borkes1985 Sun, 01/11/2009 - 22:28
By external application, for example - http requests with parameters with different values. It may be a shell script with wget:
http://ipccx_ip:8080/dialout?number_to_call=5551111
In Get Http Contact Info you retrieve the number_to_call parameter and set you variable, which you use for Place Call, equal to number_to_call (i.e. 5551111).
You may use an array of numbers, and so on.
http://ipccx_ip:8080/dialout?numbers_to_call=5551111;5552222;5553333
ra_jeshkalra_2 Tue, 01/13/2009 - 02:41
We can call OPEN URL DOCUMENT in debug mode and see the step executed(calling out a phone number,the phone rings).
It is opening simple local http page.
But it never executes(calls out a number) when we call the IVR SCRIPT without activating the debug mode.
Is there any limitation regarding OPEN URL DOCUMENT or any setting to allow this function work properly?
>>Pls see the script attached.
