ASA - SSH failure
Answered Question
Jan 8th, 2009
Hello All,
another sily issue, I configure an ASA so i could access it through ssh. Everything is configured as described in the cisco user guide but surprisingly enough, it does not work...
I tried ssh v1 and 2, I zeroized the key and regenerated a new one but it still does not work. Connectivity seems to be fine as I get the ssh prompt.
Any idea?
Thibault.
Correct Answer by Juan Carlos Ari... about 8 years 4 months ago
Thibault, you don't have AAA enable, try adding this commands so you will be authenticated with local database:
aaa authentication enable console LOCAL
aaa authentication serial console LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authorization command LOCAL
aaa local authentication attempts max-fail 5
Hope this help.
Overall Rating: 4 (1 ratings)
Correct Answer
Juan Carlos Ari... Thu, 01/08/2009 - 17:18
Hope this help.
deephazz02 Fri, 01/09/2009 - 01:32
Hello JC,
Thanks for your reply.
Actually the "aaa authentication enable console LOCAL" alone allowed me to login. That was the only command available out of the above list.
Thibault.
