01-08-2009 11:30 AM - edited 03-04-2019 03:23 AM
I need help to understand "ip nat outside" in the Serial1/1.4
How i can do troubleshooting over that.
interface Serial1/1.4 point-to-point
ip address 192.168.150.93 255.255.255.252
ip nat outside
no cdp enable
frame-relay interface-dlci 120
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 172.17.3.2 255.255.255.0
ip nat inside
interface Serial3/2.45 point-to-point
bandwidth 128
ip address 10.10.26.2 255.255.255.252
ip access-group a in
ip access-group b out
ip nat outside
frame-relay interface-dlci 45
ip nat pool xxxxx 10.249.22.2 10.249.22.2 netmask 255.255.255.0
ip nat inside source static 172.17.3.138 192.168.200.2
ip nat inside source static 172.17.210.12 192.168.200.3
ip nat inside source static 172.17.3.21 192.168.200.1
ip nat inside source static 172.17.3.127 192.168.200.11
ip nat inside source static 172.17.110.119 192.168.200.5
ip nat inside source static 172.17.3.117 192.168.200.12
ip nat inside source static 172.17.2.110 192.168.200.13
ip nat inside source static 172.17.100.100 192.168.200.16
ip nat inside source static 172.22.1.21 192.168.200.4
ip nat inside source static 172.22.1.23 192.168.200.6
ip nat inside source static 192.168.100.10 192.168.200.17
ip nat inside source static 172.17.3.109 192.168.200.14
ip nat inside source static 192.168.100.11 192.168.200.18
ip nat inside source static 192.168.100.12 192.168.200.19
ip nat inside source static 172.17.3.134 192.168.200.20
ip nat inside source static 172.22.1.25 192.168.200.7
ip nat inside source static 172.17.110.127 192.168.200.10
ip nat inside source static 172.17.100.103 192.168.200.21
ip nat inside source static 172.17.110.116 192.168.200.22
ip nat inside source static 172.17.110.126 192.168.200.23
ip nat inside source static 172.17.110.125 192.168.200.24
ip nat inside source static 172.17.3.137 192.168.200.15
01-08-2009 11:34 AM
Maria
Not sure what you are asking. The "ip nat outside" under s1/1.4 is matched to "ip nat inside" under fa0/0.50. Using one of your NAT statements as an example -
this says when a packet from 172.17.3.138 arrives on the fa0/0.50 interface and is routed out of the s1/1.4 interface it is Natted to 192.168.200.2.
Has this helped ?
Jon
01-08-2009 11:52 AM
The "ip nat outside" causes the same behavior in the interface Serial3/2.45 with the interface fa0/0.50?
01-08-2009 11:54 AM
Yes it will if the traffic is routed out of the s3/2.45 interface although whether you want it natted to a 192.168.x.x address is another matter.
Jon
01-12-2009 07:24 PM
This command, has some effect?, taking into account that the interface to which this associated the ip nat inside is the interface FastEthernet0/0.50?
01-13-2009 06:42 PM
Any answer?
