01-08-2009 12:10 PM - edited 03-15-2019 03:24 PM
I have been unable to locate the "edit servers" link in the Telephony Integration part of UNC admin. We want to add a second CUCM server to the integration for redundancy. Adding a second server doesn't seem to be possible either during integration creation, or after it has been created. The "Edit Servers" option doesn't seem to be displaying either in the Port Group configuration or in the Integration configuration pages. Also, once the integration has been created, there doesn't seem to be any option for viewing the ip address of the server that was identified.
01-08-2009 12:37 PM
regular CUC or CUCMBE?? if CUCMBE it's not possible
java
if this helps, please rate
01-08-2009 12:38 PM
No ... clustered. Finally found it ... wasn't available visible from other screens
