RTMT: rcopy/paste
Jan 8th, 2009
Is it possible to copy/paste in an excel doc or generate a csv file when you do a search of devices registered in CUCM ?
Results of devices registered can't be exploited and impossible to generate a report with such details.
Thanks in advance
Overall Rating: 3 (1 ratings)
pemelend Sat, 01/10/2009 - 23:00
You can go to route plan> route plan report
and you can find the "view in file" option (up/right corner)
This will creeate a csv file with all the dn's of your CCM including ip phones.
Or you can also use BAT export option to create a CSV of all the ip phones.
Neither way show if the devices are registered or not, but those are the closest options that I know to what you ask.
Pedro
