ATM over Ethernet and pseudowires
Jan 8th, 2009
Could somebody tell me if there is a Cisco Router that can work ATM over ethernet. This ATM circuits comming from an ethernet interface sholuld be transported as pseudowires through an IP/MPLS Backbone. Routers 12000 can do this? wich version do I need?
p.diaz Fri, 01/09/2009 - 08:44
Hi Narayan. Thank you.
I have now the following doubt. If we have the following topology:
Consider a lot of atm access at the right side, but we need to use only one vlan at the left side to connect all the remote atm sites.
You are telling me that we can convert the left CE in to a PE. But Can we maintain the router as a CE but terminating the ATM circuits (pseudowires) transported over one one vlan? ( atm over ethernet)
I appreciate everyting.
