Need help with turning off Inspect h323 on my ASA
Answered Question
Jan 8th, 2009
I've been told that this will fix my issue with having our Avaya VPN phones drop connections and call quality but no one can tell me how to make the change on my ASA.
Cisco ASA:
policy-map global_policy
class inspection_default
no inspect h323 h225
no inspect h323 ras
I've tried doing it from the command line but I must have the syntax wrong so any help would be appreciated. Should I do it from the ASDM or command line? Step by step help would be great. Thanks.
Correct Answer by Mark Yeates about 8 years 3 months ago
That is correct it is no longer displayed if it is removed. Save the config and you are all set!
Mark
Overall Rating: 5 (1 ratings)
Mark Yeates Thu, 01/08/2009 - 13:56
  • Gold, 750 points or more
Aaron,
did you type configure terminal first?
configure terminal
no inspect h323 ras
HTH,
mark
aaron.grussner Thu, 01/08/2009 - 14:01
Yes and it kept giving me an error when I would enter the no inspect lines. This is the error I get: ERROR: Inspection not installed or parameters do not match. Thanks.
Mark Yeates Thu, 01/08/2009 - 14:08
Are you sure they haven't already been removed? I just checked with my ASA and removed it and pasted it a second time and gave me the same error. Can you please post the following output.
show run | inc inspect
Mark
aaron.grussner Thu, 01/08/2009 - 14:22
policy-map type inspect dns migrated_dns_map_1
inspect ftp
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
inspect icmp error
inspect ipsec-pass-thru
inspect pptp
So it no longer displays it once its removed? So now I just need to write it to memory wr mem and its all set?
Correct Answer
Mark Yeates Thu, 01/08/2009 - 14:24
Mark
Mark Yeates Thu, 01/08/2009 - 14:27
You are most welcome.
Best of luck!
Mark
