WS-C2960-48TT-L has 2 1000BaseTX or 1000BASE-T ports?
Jan 8th, 2009
As I know this standards are different, and 1000BaseTX need a CAT6E cable to operate.
show run says that:
Gi0/2 notconnect 1 auto auto 10/100/1000BaseTX
but here:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd80322c0c.html
is said that "1000BASE-T ports: RJ-45 connectors, 4-pair Category 5 UTP cabling"
Where is the truth?
glen.grant Thu, 01/08/2009 - 17:26
  • Purple, 4500 points or more
Gig will run fine on cat5E cable and probably most cases on cat 5 .
amikat Fri, 01/09/2009 - 05:59
  • Silver, 250 points or more
The ports in question are 1000BASE-T ports as the document corretly specifies (ie. compliant to IEEE 802.3ab specification). The 1000BASE-TX standard (as prepared by ANSI/TIA/EIA not IEEE) has never reached the extent as expected and is currently rather dormant in my view. I believe that Cisco is aware that there are 2 different standards. My understanding is that when a port displays 10/100/1000BaseTX (and this is not specific to WS-C2960-48TT-L box) it actually means that it is compliant to 10BASE-T, 100BASE-TX and 1000BASE-T compatible devices.
Best regards,
Antonin
