Jan 8th, 2009
I have ASA5505 as firewall and VPN. I have two questions.
1. My Exchange is internal. I want to use port forwarding to forward all tcp 25 traffic to Exchange server. How can I do that? I can't figure it out.
2. With VPN connected, user can not browse Internet and sending/receiving email. It seems port 80/25/110 has been closed. but don't know where to open them.
Any help will be appreciated!
Thanks in advance!
Collin Clark Fri, 01/09/2009 - 07:47
1. Try the following command-
static (inside,outside) tcp 25 [public IP or interface name] 25 [IP of Exchange Server] netmask
static (inside,outside) tcp interface 25 25 netmask
or using a public IP
static (inside,outside) tcp 25 25 netmask
You'll have to adjust your firewall ACL to allow it through as well-
access-list external-interface extended permit tcp any host eq smtp
2. This depends on the VPN config. You're probably tunneling all traffic and then you don't have a NAT/ACL block or something not allowing VPN users to be able to get to the internet.
Hope that helps.
