ISDN BRI issue on Cisco 2610XM
Jan 8th, 2009
Hi every body,
2610XM with 1 WIC 1B S/T in Onnuch. Not able to make ISDN calls from Dindeang. Calls answered, PPP authentication. But price of call from ISDN status normal is $25 per month. Now can't connect from Dindeang to Onnuch but price of call from ISDN is $2800 per month and can't connect to either silte.
Then my customer can't to pay with ISP. I want issue for possible and I show config router 2 sites this below.
Onnuch configure
bkkonnuch#sh run
Building configuration...
Current configuration : 1436 bytes
version 12.3
hostname bkkonnuch
boot-start-marker
boot-end-marker
card type e1 1
enable password passonnuch
username bkkr3 password 0 passisdn
username dtcras password 0 passisdn
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-net5
controller E1 1/0
line-termination 75-ohm
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 192.168.3.253 255.255.255.0
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation ppp
dialer rotary-group 1
dialer-group 1
no cdp enable
interface Dialer1
description connected to bkkr3
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 28800
dialer load-threshold 1 either
dialer-group 1
peer default ip address pool Group1
no cdp enable
ppp max-bad-auth 3
ppp authentication chap callin
ppp multilink
router eigrp 100
redistribute connected
redistribute static
network 192.168.3.0
no auto-summary
ip local pool Group1 192.168.3.100 192.168.3.150
ip classless
ip http server
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
Dindeang Configure
bkkr3#sh running-config
Current configuration : 1522 bytes
version 12.3
hostname bkkr3
boot-start-marker
boot-end-marker
enable password passbkkr3
username bkkonnuch password 0 passisdn
no aaa new-model
ip subnet-zero
ip cef
isdn switch-type basic-net3
ip address 172.18.3.154 255.255.255.0
duplex auto
speed auto
interface BRI0/0
no ip address
encapsulation ppp
shutdown
dialer-group 1
no cdp enable
interface Dialer1
description connected to bkkonnuch
ip address negotiated
encapsulation ppp
dialer in-band
dialer string 023285100
dialer string 023285101
dialer string 023285122
dialer string 023285102
dialer-group 1
no cdp enable
ppp multilink
router eigrp 100
redistribute static
network 172.18.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.18.3.1
ip route 192.168.1.0 255.255.255.0 172.18.3.156
ip route 192.168.2.0 255.255.255.0 172.18.3.155
ip route 192.168.3.0 255.255.255.0 Dialer1
ip http server
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
thank you so much for help me please
Richard Burts Fri, 01/09/2009 - 04:46
I believe that the issue is that the network statements under router EIGRP include the addresses used on the ISDN interfaces. So EIGRP is attempting to run on those interfaces. And the access list used by the dialer-group and dialer-list to identify interesting traffic says protocol ip permit. So EIGRP is interesting traffic and brings up the ISDN and keeps the ISDN active and prevents any other calls.
The solution for this is to rewrite the dialer-list and access list. Make the dialer-list use an extended access list and in the extended access list deny EIGRP traffic and then permit ip any any.
Rick
aleeamtech Sun, 01/11/2009 - 20:27
Hi rburts
Thank you very much for rewrite solution to me.
I 'll to rewrite configure and design solution for this issue.
I 'm 'll to try solution for deny EIGRP routing and places configure to static routing .
how do you think about it ?
Richard Burts Mon, 01/12/2009 - 05:23
I do not understand your statement:"for deny EIGRP routing and places configure to static routing". I am not sure what static routing has to do with it.
I believe that if the access list for the dialer list makes EIGRP non interesting that the problem will be resolved.
Rick
