NAT Problem with SIP Connections on 878
Jan 8th, 2009
we are using SIP to connect SIP phones to a SIP solution in our datacenter. The connections are build with Cisco 878 routers. We are making NAT on these routers.
We are using the following software:
Sometimes calls are not be established. I can see the following to NAT entrys for one source port:
sh ip nat trans
udp x.x.x.y:5005 x.x.x.x:10001 x.x.x.x:10001
udp x.x.x.y:5005 x.x.x.x:10057 x.x.x.x:10057
udp x.x.x.y:1050 x.x.x.x:5060 x.x.x.x:5060
udp x.x.x.y:1054 x.x.x.x:10184 x.x.x.x:10184
udp x.x.x.y:1055 x.x.x.x:10185 x.x.x.x:10185
udp x.x.x.y:1053 x.x.x.x:5060 x.x.x.x:5060
If these two nat entrys for one source port and IP combination the call can not be build up.
Did somebody had the same problem?
Is that a software problem?
Thanks and best regards,
