MPLS delivered with G.703
Jan 9th, 2009
All,
Can you help? I am trying to provide backup to a remote site and the second line has been presented with a G.703 signaling on a RJ-45 interface. A few months back someone on here recommended a VWIC2-1MFT-G703 module. This module doesn't work with a 1721 or 1841 router.
Any ideas on how to get this working? The module shows in the hardware profile but doesn't show when you do a sh ip int brief.
Giuseppe Larosa Fri, 01/09/2009 - 04:39
  • Hall of Fame,
    Founding Member
Hello Isaac,
it should be a question of IOS image on both routers.
C1721 can support the module for data only but it is what you need.
see
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
see table 1 you need at least
12.3(14)T on 1721
to see the corret image you can use
www.cisco.com/go/fn
Hope to help
Giuseppe
royalblues Fri, 01/09/2009 - 04:43
  • Green, 3000 points or more
Giuseppe
VWIC2-MFT-G703 is not supported on the 17xx platform but VWIC2-MFT-T1/E1 is supported
Narayan
royalblues Fri, 01/09/2009 - 04:53
Conflicting information on the data sheet for both of them :-)
I think the best way would be foe him to upgrade the IOS and test
Narayan
iadegoke Fri, 01/09/2009 - 04:55
Many Thanks guys. I only have the 1841 running 12.4(1c). I will power on the router and define the card settings and see what happens
iadegoke Fri, 01/09/2009 - 08:58
The router sees the card now. I installed with default values. The alarm light is on (no line is connected at present) but what I am worried about is timeslots. I sued 1-31 (default E1 since I do not have any info from the providers). I hope this works when I send it to the location.
royalblues Fri, 01/09/2009 - 23:46
The G703 module supports both framed and unframed..
The timeslots configuration is fine if it is a framed circuit. If unframed you can use
channel-group 0 unframed which provides 2048kbps
Narayan
