Replacing 4402s with 4404 controllers.
Stephen Rodriguez Fri, 01/09/2009 - 07:10
  • Purple, 4500 points or more
Good thing here, is if you are running LAG, you should be able to upload the current config, and then download to your new controller. If you can do this in a non-live environment, you can then just switch out the two units.
Otherwise, you're best off doing a stare and compare to make sure you have everything configured the same.
HTH,
Steve
Stephen Rodriguez Fri, 01/09/2009 - 08:41
LAG just sets all the ports to be the logical channel number, if you don't have LAG enabled, then all the interfaces will remain linked to the port you had them set to previously. Not a huge issue going from a 4402 - 4404.
As for the code, on the download of the config, the WLC should parse and do whatever upgrades/manipulations needed to get the config to what 4.2 would expect. On that note, make sure you can upgrade directly from the 4.0 release you are running to the 4.2 release the 4404 is running, release notes will tell you this.
HTH,
Steve
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
