QOS on 4948
Jan 9th, 2009
  • Silver, 250 points or more
I would like an explanation on how the TX queue work on that peice of equipement.
If I do a sh qos int ten1/49, I get this:
QoS is enabled globally
Port QoS is enabled
Administrative Port Trust State: 'cos'
Operational Port Trust State: 'cos'
Trust device: none
Default DSCP: 0 Default CoS: 0
Appliance trust: none
Tx-Queue Bandwidth ShapeRate Priority QueueSize
(bps) (bps) (packets)
1 2500000000 disabled N/A 2080
2 2500000000 disabled N/A 2080
3 2500000000 disabled high 2080
4 2500000000 disabled N/A 2080
What`s the purpose of the bandwidth field?
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 01/09/2009 - 09:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dominic
There are 4 queues on egress and each queue is allocted 1/4 of the bandwidth ie. 2.5Gbps in this case. You can change the allocation between the queues, or at least you can on some ports but i have never used a 4948-10G model.
You then map DSCP/Cos values to queues.
I suspect you may after something more specific. Attached is a link to Egress configuration on 4900 -
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/qos.html#wp1463276
If i have not answered your question please come back.
Jon
dominic.caron Fri, 01/09/2009 - 12:11
So, the high priority queue will be service first. The 3 other queue will share 1/3 each of the remaining transmit time. If I resume this,
1-If there is a packet in the high queue, put it on the tx-ring
2-take one packet from each other normal priority queue and place it on the tx-ring.
3-Start over
There is probably a check to see if the high priority queue is empty between each lower priority packet been put on the tx-ring.
Am I on the right track ?
dominic.caron Fri, 01/09/2009 - 12:15
I've just read the link, got my answer, thanks.
