Testing VIC2-2FX S and VIC2-2FXO cards
Jan 9th, 2009
I want to setup two 2611XM routers with a
NM-HD-2VE ( 3 DSP), VIC2-2FXS, VIC2-2FXO cards.
Can I connect the FXS to the FXO ?
Do I need to have telephones with RJ11 Straight through cables connected to the ports of the VIC's.
Could you point me to somewhere where this scenario is addressed. ( Voice certification test lab diagrams...)
Thank you,
Tom
Nicholas Matthews Fri, 01/09/2009 - 08:26
  • Red, 2250 points or more
Hi Tom,
FXS will always connect to FXO. Consider your provider to be FXS, and analog phones to be FXO ports.
You should be able to use a normal telephone cable to connect between the FXO and FXS.
I don't know of any documents that specifically say anything for back to back FXS/FXO, because they are documented separately normally.
hth,
nick
sandeep.karwall Wed, 12/14/2011 - 03:07
Dear Experts
This is going to be my first implimentation of the Voice network and is turning out to be a nightmare.i have reffered all the configuration mannuals , books and videos but still not able to make calls across the MPLS network.Need help urgently to solve the issue.
Here is the senario
PSTN>>>FXO(Cisco2905)>>>>>MPLS Cloud<<<<<<<(Cisco2905)FXS>>>>>>>>Phone
here is the configuration i have done
voice-port 0/1/0
voice-port 0/1/1
connection plar 2201
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dial-peer voice 998 voip
destination-pattern 22..
session target ipv4:192.168.220.1
dtmf-relay cisco-rtp
dial-peer voice 100 pots
destination-pattern 9............
port 0/1/1
on
voice-port 0/0/0
cptone ID
voice-port 0/0/1
cptone ID
dial-peer voice 220 pots
destination-pattern 2201
port 0/0/0
forward-digits all
dial-peer voice 221 pots
destination-pattern 2202
port 0/0/1
forward-digits all
dial-peer voice 110 voip
destination-pattern 9T
session target ipv4:192.168.0.1
Early response is much appriciated
REGARDS
SANDEEP
